MAP problem
Old Jun 14, 2003 | 01:57 PM
cobrakiller1989's Avatar
MAP problem
i just finished swapping from MAF to MAP and im now running the 730 ecm. i hooked the scanner up today to see what the trouble code i had was and it was a 33. long story short, my MAP is reading 86kpa at all times, even when the car is off, i imagine i have something wired wrong somewhere...can anyone help me out here? thanks alot
Old Jun 14, 2003 | 08:30 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: MAP problem
Possibly a bad sensor.
Is it referenced to a good manifold vac source?.
You should have 5v at one pin, ground, and then like 4.8v ish volts, engine off. Popping the vac line on and off should make the ouput jump from like 2.5 to 4.8 with the engine running.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
