hissing out of air intake
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
I got a feeling this is being caused from the IAC,it is a extremly loud hissing, is it doing this for cold start higher idle, if so why doesn't my cars idle go higher for cold starts, it only does this when cold then goes away after a few minutes, am I dealing with a plugged IAC bypass, Ive cleaned the throttle body but it still does this, are there air passages in the plenum that could be plugged, its a 90 tpi with speed density
it is possible the IAC park postion has a worn spot. on gm the park
postion is usually 160 and the IAC may have a worn spot and can
not clear the spot.
using a scanner, you should be able to command and lower postion
and see if this clears the issue. if not, look into a ECT sensor or
rick O2 sensor.
airdeano
not clear the spot.
rick O2 sensor.
airdeano
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
possibly a vacuum leak. if u wanan test for leaks,get some propane, witht eh car running,let a litle bit go around all the gaskets and vacuum lines. since propane is heavier, it will set around the manifold...if theirs a leak,the idle will jump up a little.
camaro, the noise is IAC related
Transmission: t-5
alright,i ithink i mis read it,i thought it was coming from the intake manifold,not the intake tube.
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
