Happy with 406 HSR set-up...
Old Jun 16, 2003 | 06:15 AM
Cam28_boy's Avatar
My first week driving it and i'm just totally satisfied. I do have some issues that need to be resolved but there no big deal. The torque is definately there at the bottom end and throttle response is supurb. I don't know what 11 second 1/4 mile times feel like but I definately think I might have one.
Here's what I have: 406sbc, with Holley Stealth Ram intake and fuel rail. Accel 32# injectors. Holley Adjustable Fuel Pressure Regulator, MSD6A, Holley Fuel Pump, Sphon adjustable torque arm, lakewood lower control arms and panhard rod. Th350 transmission, slp 1 3/4 headers with flowmaster exhaust, oil cooler from be cool, cooling fan relay, comp cam .525" lift (don't know right off hand...simular to hot cam but retrofit) 1.6 rocker arms. No air conditioning or air pump no emissions whatsoever. TCI torque converter 2400-2800 stall. Chip was burn my someone locally...so far it has worked fine.
:lala:
Old Jun 16, 2003 | 06:19 AM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
Sounds nice.. Any pics of the setup?
Old Jun 16, 2003 | 07:23 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Sounds good! Maybe one day my 406 Stealth Ram will come togther... Did you have any problems getting your accessory brackets to line up correctly? My Stwearts Stage 2 water pump is a little too bulky in some areas and interferes with the pass. side bracket, and I think I may have issues with the drivers side as well.
Old Jun 16, 2003 | 09:14 AM
Cam28_boy's Avatar
I don't have any pic's right know but I will have some in a couple of weeks. I will also have some track results. I didn't have any problems with the accessory brackets. Everything lined up perfectly. I'm having problems with the idle though.
Old Jun 16, 2003 | 03:09 PM
ski_dwn_it's Avatar
Engine: 2 mice and a cat
Good luck man! Hope it cranks for you!
InfernalVortex
Apr 20, 2021 11:31 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
86z89iroc
Oct 5, 2015 01:04 PM
mike22115
Sep 28, 2015 04:49 AM
BBSDesigns
Sep 22, 2015 03:08 PM
