400 build up head options?
Old Jun 17, 2003 | 08:06 PM
mastrdrver's Avatar
Does anyone have an option on what heads I should put on this? It will be a 400 with 5.7 rods, HSR, XE288 HR, 1.5 nsr rr, headman 1 3/4 lt with duals. I am constricted to use a head that can accept a felpro 1205, but no bigger. I have been looking at AFRs 210, but also have been thinking of getting some ported heads that would fit a 1205. Anyone got any ideas?
Jeremy
Old Jun 17, 2003 | 09:26 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
My Pro Action heads were a great deal for the $$$...and they are port matched to a 1206 gasket...
I hate to tell you, but I believe that any head with 210cc intake runners or larger (like up to 235) use a 1206 gasket...
I have no problem with the fact that my Stealthram uses a 1205...going from a smaller port to a slightly larger port is ok...but the other way is a no-no...
It isn't ideal, but should work fine for you...
Old Jun 18, 2003 | 01:29 PM
mastrdrver's Avatar
Do you get a good enough seal around the port? I was thinking about using the Dart 227 CNC heads as long as I can get a good enough seal around the port.
Vintageracer
Jan 10, 2020 05:33 PM
italiano67
Dec 11, 2016 09:21 AM
camaro71633
Sep 1, 2015 10:24 AM
lakeffect2
Aug 23, 2015 08:44 AM
