Roller Rockers
Old Jun 19, 2003 | 08:51 PM
agibby5's Avatar
Car: 1986 IROCZ
Transmission: 700R4 w/ stage 2 shift kit
Roller Rockers
I have a stock 1986 305 TPI LB9. I want to get some roller rockers. How do i know what kind to get? Self aligning or not? What other kinds are there? How do you install them without any trouble? Thanks alot in advance.
Old Jun 20, 2003 | 05:28 PM
tpi_roc's Avatar
If your heads are stock then you dont need self aligning, and the size is 3/8".
Self aligning rockers dont have anything to guide the pushrods (its a part of the rocker)
non self aligning rockers have guideplates or the heads guide the pushrods
the size is your stud, stock studs are 3/8", 7/16" is usually aftermarket studs.
If you're going to buy them get 1.6s
Old Jun 20, 2003 | 05:57 PM
agibby5's Avatar
Car: 1986 IROCZ
I want to get some roller rockers and bolt them on to my stock heads but then be able to switch them over to some aluminum heads when i get them. Which would i need SA or non SA? and who makes good roller rockers? Also, do i need to get new pushrods or springs with the stock heads?
Old Jun 20, 2003 | 05:58 PM
tpi_roc's Avatar
You want non self aligning
Even with aftermarket you can throw on some guide plates and use your non SA rockers.
If you buy SA now you can't use them on your heads
Old Jun 20, 2003 | 07:49 PM
daxfas26's Avatar
Car: cobalt ss/sc, 91 z28, 92 z28
Engine: 385 stroker
Axle/Gears: stock 10 bolt 3.73
another thing to remember is to make sure u get rocker arms that will fit for stock valve covers and they make narrow body rocker arms for centerbolt valve covers
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
