i whant a 13
Old Jun 20, 2003 | 09:30 AM
DOOSKI's Avatar
Car: 1990 Trans Am GTA
Engine: 5.7 TPI 350 sd
Transmission: A4
i whant a 13
Please tell me i can run in the 13´s. I have a 350 GTA map -90 that has a chip and k&n filter. next week i´ll order hooker headers 2055 and 3" exhaust, Afpr, coil and wires + i will port the plenum. The car is in great condition!! What do you say?
Old Jun 20, 2003 | 11:04 AM
tpi_roc's Avatar
Doubt it but good luck
If you want to increase your odds borrow some slicks.
Old Jun 20, 2003 | 02:33 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
get some drag radials, and what gears do u have? 2.77s? GET RID OF EM!
Old Jun 20, 2003 | 05:07 PM
FactoryFreak's Avatar
Car: 1988 GTA
Transmission: TH350
Drop some 4.11's in her with 28" Slicks and a 150 shot Nitrous kit and expect 12's for around $1500.
Old Jun 20, 2003 | 05:08 PM
tpi_roc's Avatar
4.10's with TPI?
uhhhh
Old Jun 20, 2003 | 05:10 PM
Car: 1988 GTA
Transmission: TH350
If you put 28" Slicks on her she'll make down the 1/4 just fine.
Old Jun 20, 2003 | 05:11 PM
tpi_roc's Avatar
Chances are he wanted to keep it road worthy
slicks will come off when he tries to get home
Old Jun 20, 2003 | 05:19 PM
Car: 1988 GTA
Transmission: TH350
Then go get some 27 or 28 inch street tires and be done with it.
Old Jun 21, 2003 | 01:40 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
255 50 16 BFG drag radials or 26" tall ET streets with 3.27s or 3.45s is all he needs. even 3.73s are to much, even with a 5spd. i have 3.27s and run past 5k pretty easily
Old Jun 21, 2003 | 01:50 AM
Car: 1988 GTA
Transmission: TH350
I've seen plenty of cars with 3.73's run through the trap in 3rd gear so i'm guessing 5 speeds can make it in 4th gear. With the bigger tires it will raise the ratio some. He should be fine with 3.73's. On my car i'm putting 4.11's, i'll let you know on the results.
Old Jun 21, 2003 | 01:08 PM
DOOSKI's Avatar
Transmission: A4
I´m not in for slicks, its daily drivers car!!!! so i can´t get into the 13´s DAmn!! because stock it went 14,43 i think and it has a 3.23 not 2.77. So these mods cant give me 4-5 tenths
Then i have to save upp for more money.......
Old Jun 21, 2003 | 01:23 PM
tpi_roc's Avatar
Its the name of the game
It either takes alot of power, or alot of traction.
devilfish
May 20, 2014 10:36 PM
bajorf
Sep 16, 2008 03:24 PM
501dave
Feb 3, 2008 02:34 PM
DOOSKI
Oct 15, 2002 09:31 AM
DOOSKI
Theoretical and Street Racing
21
Oct 12, 2002 04:20 PM
