1989 Formula 350 stalling, not running well
Old Jun 22, 2003 | 01:51 PM
corona light's Avatar
I am looking to buy an older Fbody(just sold my 1998 LS1) for a project and to have something. I found a black 1989 Formula 350 w/fair body, t-tops and L89 350v8. Guy says he's orig owner with 71 or 72k miles. Problem is motor stalls or doesn't run well. I am somewhat mechanically savvy, however; I don't know jack about these years of cars and what could be the problem. I assume it's a sensor, or ignition component or maybe even problematic injectors.
any thoughts to help me out?
thanks
Old Jun 22, 2003 | 01:58 PM
GNR4EVR's Avatar
Timing or ignition problem, maybe?
I'm no expert, either
Old Jun 22, 2003 | 02:07 PM
patrickm00's Avatar
i'd check for codes first (see tech section), but maybe Mass Air Flow (MAF) sensor, but i'd also check the plugs, air filter, etc. 'stalls' isn't really enough to go on though. any more details?
Old Jun 22, 2003 | 02:09 PM
patrickm00's Avatar
and see if it runs ok if you jump the A and B terminals on the ALDL diagnostic connector under the dash on the right. A and B should be the top two right pins.
Old Jun 22, 2003 | 03:34 PM
i appreciate help guys
I haven't looked at car yet so I am trying to troubleshoot off of what this guy tells me and to be honest he isn't too car literate . Anyway, it's prolly between this car and an 1989 iroc w/ 350 and 118k miles w/rebuilt tranny w/racing guts per owner. I kinda prefer the iroc look and I want to build a motor to put in a car and paint it canary yellow anyway so I might get the iroc if I like it. But this formula could be had cheaply and it might be an uber easy fix
when I jumper the connector what do I use, just some wire to loop the two imputs?
thanks
Old Jun 22, 2003 | 03:54 PM
patrickm00's Avatar
yeah, a wire is good, or a paper clip will also work. to get the codes jump it, and turn the key to run, but don't start the engine.
it's kinda like morse code, one blink = 1, then pause, then two =2, then long pause == code 12 (checkout). code 12 will flash 3x, then real codes start. 12 just means the code output works right.
but also try running the car jumped (diagnostic mode)
Old Jun 22, 2003 | 07:13 PM
stupid ? again. What does jumping the A and B terminal do. Does it bypass something to allow it to run better if say a sensor is bad, or does it just report diagnostics
thanks
Old Jun 22, 2003 | 09:55 PM
T/A gets T&A's Avatar
Once you jump the A and B terminals, turn the key to the run position but DO NOT ATTEMPT TO START THE CAR. Doing so could damage the ECM (computer). Once your key is in the run position and the jumper wire in place, the service engine soon (SES) light will begin to blink. It will blink a numeric code that will help you diagnose different problems the computer may have recorded. Take a look at the technical section of this site and you will find out everything you need to know.
camaro11j
Sep 19, 2018 08:49 AM
okfoz
Mar 9, 2017 02:35 PM
theshackle
Mar 5, 2017 06:37 PM
kyleb24
Aug 15, 2015 08:24 AM
