Removing plenum, how many bolts?
Old Jun 23, 2003 | 06:54 PM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
I am starting to take off my plenum and runners. There are just 8 bolts correct?
It looks like the alternator bracket counts as one bolt for the passengers runner.
I just want to make sure there aren't any other hidden bolts anywhere. I also can't seem to find more than one bolt on the passenger runner (front two tubes) besides the one which the alternator bracker it attached to.
Old Jun 23, 2003 | 09:02 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
There are 2 under the plenum..you have to take the plenum off to get to them from the back side of the runners.
Old Jun 23, 2003 | 09:45 PM
Christos's Avatar
Nuts, hoping I could disconnect the bottom of the runners, and lift it all off.
Man some of these are tough to get to! I'll work on it more tomorrow. Thank you wishmaster!
Old Jun 23, 2003 | 09:57 PM
MelloYello's Avatar
If you remove the top bolts of the runners, the plenum should slide out from between them with a slight nudge
Old Jun 24, 2003 | 12:21 AM
89formula35O's Avatar
yeh those little bastards in the back like to hide.
Hawkeye1980
Aug 31, 2015 07:09 AM
TheExaminer
Aug 26, 2015 04:59 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
355tpipickup
Aug 22, 2015 06:06 PM
3rdgenparts
Aug 8, 2015 07:09 PM
