need help putting in egr solenoid
Old Jun 24, 2003 | 12:57 PM
jodylee8310@aol's Avatar
I had the motor rebuilt in the car and they forgot to put back on the egr solenoid. I found the solenoid and ive found the electrical connector on the wirring harness but i cant find the vacuum lines that run to it ,dont they run from the fire wall somewhere and connect to the solenoid and then from the solenoid to the egr valve and to the vacuum connector at the very front bottom of the plenum. this is a 1987 transam with 5.7ltr 350
Old Jun 24, 2003 | 01:55 PM
kevinc's Avatar
Car: 1982 Z28
Re: need help putting in egr solenoid
Not 100% sure on the '87, but on my '88 it was fed vacuum from a fitting on the underside of the throttle body (driver side) and a hard plastic line that fed EGR and some other thingies mine no longer has.
Check the underside of your throttle body driver side for the fitting, if it's capped just fab up a tube to get it back to the EGR solenoid, then from there to the EGR valve itself. You can buy the rubber elbows and hard plastic tubing at Advance Auto and probably other stores.
Old Jun 24, 2003 | 04:06 PM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
Just go drop $20 on a chilton's. They have the vaccuum diagrams plus lots of other stuff you will eventually need...
Old Jun 27, 2003 | 11:31 PM
i know the two outlet vacuum hoses go one to the egr and the other to the front bottom of the plenum but what im looking for is the vacuum line that runs to the back of the solenoid, where does it come from?
Old Jul 1, 2003 | 10:03 AM
jamr0d's Avatar
i had the same question the other day.. I found out that it is just a vent..
https://www.thirdgen.org/techbb2/sho...hreadid=187807
Old Aug 9, 2011 | 03:48 PM
shaun223's Avatar
i was wondering the same thing i have the one going to the egr valve and the other going to the front underside of the plenum but then i cant figure out what goes into the back of it, it looks like a vacuum line hooks up to it. so then your saying nothing hooks up to the back of it just leave it the way it is ?
jklein337
Sep 19, 2018 06:23 PM
dyeager535
Aug 28, 2015 08:10 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
