Is the ign system wired into the Passkey module?
Old Jun 24, 2003 | 07:20 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Obviously it is too top secret to list in the repair manual. I lost spark then lost crank, I bypassed the Passkey module and restored crank now I need to know if the Passkey module is wired into the ign system too. And if so, how do I bypass it? Not sure if the aftermarket bypass is working properly and I want to bypass ithe module totaly.
Old Jun 24, 2003 | 08:13 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
On my 89 TPI from a Iroc Z. The VATS system, or passkey only disable my injector pulse. I would find a noid light and check if the pulse is there. Also check for spark just to make sure.
Old Jun 24, 2003 | 09:26 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Almost postive I am getting fuel, I can smell it after cranking it and have fuel pressure. I am getting no spark from the coil but do have 12v going to it. If the passkey is not wired into the ign than I can eliminate that as a possible cause. I am uncertain as to which wire coming from the accel computer is the ign trigger.
midge54
Dec 27, 2019 04:14 PM
Caspar
Jun 19, 2016 11:19 PM
crazynights
Aug 21, 2015 06:53 AM
stalkier
Aug 13, 2015 12:59 PM
