Is there that can stop fuel coming from injectors during startup?
Old Jun 26, 2003 | 03:22 PM
Night Hawk's Avatar
quick question....my car isn't starting and I tested the fuel pressure and it is perfectly normal. Is there anything stopping the injectors from firing if it is getting lots of pressure during startup? Is there an injector relay or something? My oil pressure is perfect as well.
Old Jun 27, 2003 | 07:18 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Is there that can stop fuel coming from injectors during startup?
ECM needs distributor reference pulses in order to fire the injectors.
RBob.
Old Jun 27, 2003 | 02:42 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
It gets those pulses from the pickup coil...
Old Jun 28, 2003 | 09:24 PM
Vader's Avatar
TPS voltage over 3.91 at cranking will invoke the "Clear Flood" mode and curtail all injector pulses.
Ghettobird52
Jul 5, 2024 11:18 PM
jklein337
Sep 19, 2018 06:23 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
