Ok guys. One dumb question.
Old Jun 27, 2003 | 10:43 PM
87irocz350's Avatar
Car: 87 Iroc
Transmission: T-5 3.42's
I was at a car show tonight. And I saw alot of Hot Rods running a TPI intake. But I also noticed that some of the 3rd gens had cone filter instead of the air box setup.
So, heres my question. Which is gives you better air flow. Stock air box that has been gutted, or a cone filter. Oh, also, how hard is it too hook up a cold air intake to a cone filter?
Old Jun 27, 2003 | 11:21 PM
bigals87z28's Avatar
Car: Check The Sig
well, a strait cone filter mounted on to the tb of the set up would mean that the engine is a MAP set up, and your 87 has a MAF so you could not do that. The Filter flows very well, but it flows very hot air very well... Actualy, the camaro y snorkle will flow very well after gutting the boxes. Just take out the bottom part thats attached to the nose, and go at it man! i used a dremmel with 2 crappy cut off disks... watch out for melted plastic, cause i got it stuck all over my arms and face.. wear eye gear and something with long sleeves. good luck man. nice car too!
Old Jun 28, 2003 | 11:51 AM
T/A gets T&A's Avatar
Well he just beat me to the post... I say ditto.
Old Jun 28, 2003 | 12:58 PM
JR305's Avatar
I am going to run the stock filter assembly on my engine, with the air boxes gutted. I have read a few threads where this has come up before and the general consensus was that the stock assembly works great. The Cone filter actually works the worst, as tested in the magnum TPI project( I think that’s what it was called).
Old Jun 28, 2003 | 01:00 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
When I did my TPI swap few years ago, all I could get my hands on at the time was a cone filter. I ran the car at the track several times. Then when I finally got a Cold Air Intake, I shaved two tenths off my track time with no other mods. Take it for what its worth, engines like cold air better than air thats been passed through a 200° radiator.
Old Jun 28, 2003 | 02:43 PM
87irocz350's Avatar
Car: 87 Iroc
Thanks for the replies guys.
Ive been wanting to gut the boxes for a while now...looks like some other people and this thread have been also. But, when I do it I will run some duction from the fog lights to the filters. Im not quite sure how I will get them to stay.......but, duct tape fixes everything I guess. Ill keep you guys updated on this project.
ZZ3Astro
Aug 13, 2019 12:57 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
corey8084
Sep 17, 2015 02:56 PM
Rally Smith
Sep 14, 2015 06:59 PM
Ian Irvine
Sep 4, 2015 08:08 AM
