Code 43 and Limp Mode
Old Jun 28, 2003 | 11:15 PM
GhoSSt's Avatar
Had a guy I'm trying to help. Converted an LG4 305 car to SD TPI with a 7730 ecm. Car idles ok, revs up strong, but under load runs like crap. We also can't shake a code 43 that keeps popping up. "Faulty Electronic Spark Control". Memcal is new, and works good in another car.
He's still using the LG4 knock sensor and I think its freaking the ECM out and forcing limp home, hence the poor performance. Any thoughts guys?
Old Jun 29, 2003 | 12:59 AM
robert1's Avatar
Code 43
I converted to a SD system too and kept getting 43. It just went away after a while for no reason. I do know that you must get a Knock Sensor for the 350 inch engine. When you say runs bad at WOT, do you mean flat, it won't accelerate or what?
Old Jun 29, 2003 | 01:14 AM
GhoSSt's Avatar
Re: Code 43
Its a 305. We just put the tuned port on top of the existing 305ci engine. So I'll need to convince this guy to swap over to the 305 SD knock sensor. He doesn't want to spend anymore. LOL
Well, it revs up fine in park, but man, once you get it out on the street, its a dog. No ***** at all. Like it dead. Won't accelerate at all.
Old Jun 29, 2003 | 09:19 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
the resistance is diferent between the two sensors, my car did the same things and a 43, use a 90 up sensor and the code will go away
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
