five7kid CO emission test help!!
Old Jun 30, 2003 | 05:43 PM
chevyismine's Avatar
Car: 91 GTA
Engine: 383 TPI
i need to know what CO does for emission testing? Hydrocarbons? CO? NOx? visual? sniff? thanks in advance
chevyismine
Old Jun 30, 2003 | 08:46 PM
IROCthis88's Avatar
Car: 1988 iroc-z all stock for now
Engine: LB9 305
Transmission: 700R4 3.42 posi rear
CO emissions are a by product of combustion process and result from incorrect air/fuel mixtures
Old Jul 7, 2003 | 04:03 PM
IROCthis88's Avatar
Engine: LB9 305
in other words, your leanin the engine out, too much air and not enough fuel
Old Jul 7, 2003 | 10:20 PM
Car: 91 GTA
Engine: 383 TPI
sorry about the confusion - i meant co as in colorado emission laws, not carbon monoxide. anyone that knows colorado's emission laws that would like to help are urged to reply. thanks
Old Jul 14, 2003 | 01:59 PM
Car: 91 GTA
Engine: 383 TPI
repost
Old Jul 16, 2003 | 04:17 AM
IROZINCO's Avatar
CO emissions
It depends on where you are. Some counties in CO don't test at all. The major metro areas (DEN, COS) do. Denver has the highest restrictions, they dyno test anything newer than 1982. Colo Springs doesn't dyno, but they are looking at CO, NOX and that all your gear is there. (cat, air pump, cannister etc) See this link http://www.mv.state.co.us/emissions.html for all the details.
Old Jul 16, 2003 | 10:56 AM
owned's Avatar
Re: CO emissions
What he said. Anything newer than 1982 needs an e-test every 2 years, older EVERY year, in urban counties. Most counties outside metro denver use a simple idle and 2500 rpm test, at no load at idle. It's pretty easy to pass, assuming you car is operating right.
Visual test consists of checking for an air pump and cat in cars that are supposed to have one.
Also of note is that e-tests are done by private repair shops, NOT state run emissions centers. This means that a lot of shops get a little cute with getting cars to pass, and knowing the right people, it's pretty easy to get stuff taken care of. I'm not saying that you should just hack out all your stuff and find the guy who will smog it for a 50, because I think low emissions is a GOOD THING, but it is more relaxed than a lot of states in that regard.
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Eric-86sc
Sep 28, 2015 11:37 AM
raymondandretti
Sep 27, 2015 06:43 PM
