final answer?
Old Jul 2, 2003 | 10:00 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
final answer?
http://www.competitionproducts.com/page51.html
The $49.95 cam, good or bad? better than what I have now, yeah but worth it? I just want to get my car running...I can get this and attempt to put it all back together myself...
Come guys your honest answers.......Ive searched and this is the cheapest one I can fine...I can fine one anywhere ele...plus I can get away without changing the valve springs..right?
can someone fill me in on the performace of this cam.....I am not to bright on this subject..
thanks
if it bad then can someone do some searching for me and fine what I want....
Old Jul 3, 2003 | 03:30 AM
Morley's Avatar
That seems awfully cheap for a hyd roller cam, a little too good to be true.
Most hyd rollers run about $250....So I gotta ask, why is this one so darn cheap???
Heck, thats quite cheap for a hyd flat tappet cam too.
Old Jul 3, 2003 | 09:03 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
That's a "take off" cam from a stock Vortec 350 truck engine, not a performance cam by any means.
Old Jul 3, 2003 | 10:16 AM
So it would not be a good replacement for what I have? Oh well back to the drawing board...
Old Jul 3, 2003 | 03:02 PM
evilho7810's Avatar
I wouldn't be cheap when it comes to a cam. You'll be kicking yourself in the *** for not spending an extra hundred bucks later on when you replace that one. That cam would probobly give you like 7 to 10 hp instead of 20 to 30 like a good cam would.
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
