Freeze plug in coolant passages from the factory..
Old Jul 1, 2003 | 11:31 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
last night my block heater blew out the side of the block?!! any reason that would happen??? im gonna drill some holes in the thermo cause it might have been on a close cycle when i reved it up to 6 grand?
anyways i took the heater off and was poking around and there is a freakin brass freeze plug in the cooland passages there..
my question is when you get the block heater option do they just punch the plug in and install the heater?? there is no way i can get it out as it looks like someone beat the hell outta it, i can barely get it up to the hole and its freakin ovaled and the back is all pushed in...
its lasted 30k ratling around in there.. can i just forget about it?
i've gained a whole new hate for freeze plugs
Old Jul 2, 2003 | 12:35 AM
Guest
Guest
Posts: n/a
You could just forget about it, nothing much new there.
It doesnt really matter what sorta shape the plug itself is in. If you can hook a screwdriver, or a similar tool, under the lip you can just pry the thing out of the block. They bend quite easily.
Old Jul 2, 2003 | 12:50 PM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
I found one in my 305 when I rebuilt it. I had it on an engine stand and had a bitch of a time getting it out. I ended up using needle nose vice grips and just pulling like hell. It had 103k miles on it at that point and I assume it had been in there a long dam time. I had driven it 35k w/o problems.
Old Jul 2, 2003 | 12:51 PM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
I found one in my 305 when I rebuilt it. I had it on an engine stand and had a bitch of a time getting it out. I ended up using needle nose vice grips and just pulling like hell. It had 103k miles on it at that point and I assume it had been in there a long dam time. I had owned the car for 35k w/o problems.
Old Jul 2, 2003 | 04:38 PM
Dano 00TA's Avatar
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
They're not hard to take out. That's how I take em out before I have a block dipped. I just push em in and use visegrips to grab it and pry it out.
Old Jul 2, 2003 | 11:38 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
vice grips rule.. it was a pain but i pulled that thing outta there
:lala: :lala:
i was checking everything and it was my intake that pinched off my coolant resevior line and probably built up enough pressure on my g-tech run to pop that sucker out.. scarry coulda washed out coolant behind my tire and owned me bad
oh well.. its out and its all mangled.. anyone know where i can send it back to gm?
Old Jul 3, 2003 | 03:27 AM
Morley's Avatar
:lala: :lala:
Block heaters were installed by the dealer, send it to them.
Old Jul 3, 2003 | 07:59 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Why? They won't warranty it after all this time.
Old Jul 3, 2003 | 09:29 AM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
its just a joke... warranty..lol
since they left it in my block i thought it would be kind of me to return it.. *sarcasm*
so its a dealer thing eh.. thats interesting..
here it is tho..
and i never bent it up like that getting it out either
Old Jul 3, 2003 | 12:32 PM
Briansz28's Avatar
Are there any markings on the inside of the plug?
Old Jul 3, 2003 | 04:30 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
nope.. not a mark on it anywhere
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
89 formula TPI
Oct 6, 2015 08:40 PM
FormulasOnly
Sep 10, 2015 09:07 PM
89 formula TPI
Sep 7, 2015 11:06 AM
