New TPI bolt set?
Old Jul 2, 2003 | 10:26 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
New TPI bolt set?
You guys using your old stock crappy *** STAR bolts? Im thinking of buy a TPI set from Ebay....what cha guys think?
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2421293941
or does GM dealer have bolts cheaper? and better?
thanks
Old Jul 2, 2003 | 10:53 PM
moved? its an appearance mod? isnt it? or a detailing mod isnt it?
Old Jul 3, 2003 | 07:32 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've got a stainless bolt kit that I bought from Cruzin Performance. I got the button head style, and I polished all of them. They look great, but you need to be careful not to overtighten them, because at least with the button head, it doesn't take much to strip the allen head. You also need to use never-seez on the threads otherwise they will gall.
Old Jul 3, 2003 | 08:07 AM
Cool Runner's Avatar
Car: 86 Trans Am WS6
Yeah I've had my eye on that too. I'm going to order the hex head though because I don't want to deal with allen or torx anymore. Boltlocker has a good reputation and price so I'm ordering one of their kits. Check their site first though because I've seen some people bidding over what they sell them for from their web site.
Old Jul 3, 2003 | 08:44 AM
Jim85IROC's Avatar
I can think of more than one place where you won't be able to fit a socket over a hex bolt. GM used torx for a reason. If I were you I'd stick with the allen stuff, or stock GM torx.
Old Jul 3, 2003 | 10:44 AM
Theres only 1 or 2 spots that a socket wont fit but I can always use the TORX bolts for that. The spots are I think on the bottom runner bolts...thats it..
are the stainless steel bolts weaker than the stock bolts?
Old Jul 3, 2003 | 07:16 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
I've bought one of those allen head kits from ebay, truly a waste of money, some of the bolts were the incorrect lenght, they seem to stirp out as easy as the factory ones, I threw mine away and used the factory bolts
Old Jul 3, 2003 | 11:24 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Take the bolts you want to replace to a locatl nut/bolt supply store (not a hardware, but nut and bolt specifically), and ask them for stainless cap head bolts, Metric, in those dimensions. That's all I did. Cheap.
I believe GM's torq bolts are stronger than the stainless, but consider you are bolting into aluminum. So the weakest part is the aluminum. And make sure to use anti-seeze on all bolts. Stainless does not expand at the same rate as aluminum.
Mark.
hectre13
Aug 26, 2015 08:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
Navy8125
Aug 22, 2015 07:13 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
