Just got TPI!! Please read.
Old Jul 9, 2003 | 01:38 AM
T/A_SXracer's Avatar
Car: '85 T/A
Engine: 385 full roller
well, i just got a tpi setup off of ebay. heres what the owner had to say,
"TPI setup out of a 1985 Camaro. Included is the throttle body, plenum, runners, base for early heads, 870 ECM w/ prom, 19# injectors, MAF sensor, wiring harness cut at the fuse box, and coil in cap distrib. There are also a few misc items/senors such as TPS, IAC, MAT, CTS, and EGR. All the the major connectors on the wiring harness are in tact, but some wires look cut and other connectors that I can't ID look broken."
I have a 355, and the manifolds on it allready have 02 scencors, i was just wondering if theres is ne thing neone would suggest i do before i put it in, besides porting, i allready plan this. thanx in advance, and sorry for the long post.
Old Jul 9, 2003 | 10:16 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
one thing what are the specs on the cam that is the 355?
as long it has 112*+ LSA the computer should like it.
85 year ecm + MAF (digital) system were problematic at best. you would be better off with a 165 ecm + harness + 165 MAF(analog). you can also repin the 85 harness to work with the 165 ecm. make sure you have a TPI FI Fuel tank as well. best of luck.
read up here.....
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
Old Jul 9, 2003 | 05:58 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Just so you know 19# injectors won't work with the 355.
Old Jul 9, 2003 | 06:32 PM
Car: 1988 IROC-Z
whoops forgot that.... the 19#'s will not work. get some 24#'s.
Old Jul 9, 2003 | 06:50 PM
Car: '85 T/A
is it that the 19# injectors wont work period, or just that they, wont work well.?
Old Jul 9, 2003 | 07:42 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
It really depends on how much fuel your engine needs.
I successfully ran stock 19# injectors and a chip for a 305 on one of my previous 357s with no problems at all. This was a mild 300ish hp engine though. I'm not sure how much hp a 19# injector can support, but sooner or later you'd need to go bigger to feed the engine.
What is in your 355? mild, wild?
Old Jul 10, 2003 | 12:07 AM
Car: '85 T/A
it is pretty mild, it has the mildest cam that my engine shop had in stock, it was an rv cam.
toones
Jan 6, 2016 06:00 PM
stalkier
Dec 6, 2015 11:25 PM
podiatra
Aug 31, 2015 09:53 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
