Bring down the temp?
Old Jul 9, 2003 | 09:10 PM
smiley23's Avatar
Since summer is here - what is the best way to bring the running temp down.
The fans will kick in at about 230 and bring the temp down to 180 - I would like them to kick in at 180 and bring it down to 140 or 160.
What is the best way to get this change made - temp sending unit?
Car is an 88 IROC-Z with a 5.7TPI
Old Jul 9, 2003 | 09:54 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
You could change the thermostat to a 180* or get a manual switch to so you can turn the fans on when you want then to come on.
Old Jul 10, 2003 | 03:56 AM
MdFormula350's Avatar
Hypertech Cool Fan Switch [cuts on at 176, off at 166 degrees F]
Hypertech Cool Fan Switch [cuts on at 200, off at 185 degrees F]
a good combo would be, 170 stat and the fan switch that cuts on at 200.
Old Jul 10, 2003 | 06:26 PM
smiley23's Avatar
Kool - thx MD - that is the kind of info I needed. I still feel 200 is too high for my taste - this car performs much better below 180.
So I will prob pick up the 176 switch and I will have to shop around for a lower stat (140 or so).
One more question - do you know if I need to purchase the thermal chip in order to use this? I could not find that answer on Hypertech's website.
Old Jul 11, 2003 | 01:24 AM
the lowest i would run is 160, and i wouldnt even run that low.
i dont think u will need a chip, the fan switch should turn on the fan earlier.
Old Jul 12, 2003 | 07:20 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
dont use hypercrap... check this out https://www.thirdgen.org/newdesign/tech/cool8dual.pdf
also dont run a 160.... it will mess up your puter. i just used a 180 and drilled 2 small holes in it and did the tech article, my car never hits 200 anymore.
Old Jul 14, 2003 | 09:07 AM
leirch's Avatar
I run a 195 stat, turn on both fans around 95 degrees Celcius. I'm running a 730 ecm(90-92 TPI), of course you have to be able to burn proms though.
My car never goes above 200-205d
Old Jul 14, 2003 | 12:43 PM
smiley23's Avatar
So far I have printed out the doc that SMURFN' posted - I havent had a chance to read it yet.
If I have to spend the money - I will go the route of a programable chip.
sheachopper
Jul 31, 2019 11:27 AM
David Frans
Oct 31, 2015 08:12 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
