Downside to not running a stat?
Old Jul 9, 2003 | 10:26 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I purchased my car abot 2 months ago, and have notices that the temp never gets above 160 or so. Also i used to see the temp rise in my old 86 and then drop off when the stat would open. My IROC has never done this, and I am guessing the previous owner removed the thermostat and never replaced it. How bad is this? I was thinking of going with a nice low stat and just wanted to know if its going to cause any damage down the road, or negative effects. Thanks guys
Will
Old Jul 9, 2003 | 11:38 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
your radiator is a heat exchanger............without the time to be there long enuff to let heat off, eventually it will overload the system.........
it will work when its cooler out, but u need the t-stat in there.
Cars run more efficiently when they are at 180-200 degrees than the do at 160 as well, contrary to what u see and are told..
oh well
enuff for now
LAter
Jeremy
PS u got a hyperjunk chip keeping your fans running 24/7 cause thats about alll they do
Old Jul 10, 2003 | 12:00 AM
norcalz28's Avatar
Actually my fan does run all the time, but they didn't use a chip. And I will definitely pick up a 180 stat. Lckily it stays really cool here by the coast. But I will watch it..... Car has a measly 2 core rad anyway, and I might upgrade this summer
thanks man
Will
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
Irocohio
Aug 12, 2015 08:03 AM
