Both my block drains are stripped, where else can ESC go?
Old Jul 10, 2003 | 10:57 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Im working on my 92 B4C. Both of my block drains on my 412 are stripped. Even the snap on easy outs wouldnt budge them. Now that the motor is in and they are so inaccessable to torching or tools. Where else could a person put the ESC sensor? Somewhere less sensative but still functional would be helpful. If I just leave the wire dangling the thing throws a code 43 at startup, and that makes it run like hell of course. I used to do this all the time on my 85 TPI but this 92 won't do it. Am I going to have to burn a chip and delete code 43? Im thinking of checking out the clearance to put it in the block oil pressure hole under the distributor. I'm worried that the it might be too noisy in some of these places.
Old Jul 10, 2003 | 11:07 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Do a search for "knock sensor bypass"...IIRC there's three different resistor values, one specific for your ECM.
Wire the resistor to the KS line, to ground.
You'll never detect any knock, but you'll never throw a code either.
Old Jul 11, 2003 | 12:55 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
hmm that sucks... i dont suppose it has to be near the cylinders to work? maybe a coolant output somwhere else would work?
I would think somwhere in the intake manifold may work... its right above the cylinders and frequencies travel really well through water, so the sensor should work right? maybe a bit less sensitive...
or maybe you could drill a new hole? or maybe in the head coolant passages? or if it doesnt have to be in coolant to work maybe in the fuel pump block off plate? thats sort of close.
I dunno just throwing ideas..
Old Jul 11, 2003 | 01:09 AM
25THRSS's Avatar
could you drill them out?
Old Jul 11, 2003 | 04:21 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
there is no access to drill
but king talon I like your FP block off plate idea, I will drill and tap it tomorrow.
Old Jul 11, 2003 | 09:15 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
I just hope it doesnt have to be inside the coolant to pick up the frequencies. do you have an engine managment software with sensitivity control? you could set it really sensitive and see if it picks up knock.
Old Jul 11, 2003 | 09:27 PM
25THRSS's Avatar
Just an idea, but they make special drills just for something with limited space. Maybe you could rent one to get it out.
ericjon262
Sep 11, 2015 06:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
89 formula TPI
Sep 7, 2015 11:06 AM
Amillionoh7
Sep 5, 2015 11:44 PM
