LT1 Cam?
Old Jul 12, 2003 | 12:58 AM
I RoC A Z's Avatar
Car: 1989 Camaro Iroc-Z
LT1 Cam?
Ok If I buy a LTI cam and put it in my 350 TPI, will I have to do anything but just install it? And what kind of gains can i expect?
thanks...
Old Jul 12, 2003 | 03:20 AM
85TPI400's Avatar
If you have an original 350 TPI roller cam in your engine now, it would be a waste of time to change it out for a stock LT1 cam.
The specs are kind of similar and any gain would not be worth the effort.
Just my opinion though!
Old Jul 12, 2003 | 04:08 AM
Rob 97 Z28's Avatar
Engine: D17A2, L31 based sbc, LS1, LM7
Transmission: 5 spd, built 700r4, T-56, 4L60e
Axle/Gears: 4.11, 3.73, 3.42, 4.56
yeah the Lt1 cam would have to have the Cam sprocket dowel pin ground down (to nothing bacially) so it would work on a TPI engine...the LT1s as u know have camdriven water pumps.
Old Jul 13, 2003 | 09:41 AM
Beefy89's Avatar
The LT1 cam's dowel pin sticks out roughly .600" so you need to tap it in so it's only sticking out .300".....If you can't tap it in that far then you'll have to grind it off till you reach the .300"...
As far as performance it just depends on what you want the car to do...It's not a very big improvement even if you add 1.6 rockers...Hope that helps..
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
L0tuS
Sep 4, 2015 11:16 PM
Strick1
Sep 4, 2015 07:11 AM
