MAF not working??
Old Jul 12, 2003 | 01:12 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
MAF not working??
I was reading through some posts that talked about the MAF on TPI cars.
To be honest, I have no idea what it does. My question is:
I bought my IROC about 2 months ago and have been slowly fixing things. I replaced the water pump a few weeks back and when I was all done, I turned the car on.... ran as it always had... I took it around the block - fine... I opened the hood to check for possible leaks and found that I'd forgotten to plug in the MAF sensor.
Why did the car run the same as it always had? Is it possible that mine is already bad?
I have had some idling issues that are sporatic, maybe the MAF?
Than ks
Old Jul 12, 2003 | 01:56 PM
Dano 00TA's Avatar
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
Yep, a maf will cause idle problems... You didn't get a check engine light with it unplugged?
Old Jul 12, 2003 | 02:05 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Dont quite remember if I did or not.
Old Jul 12, 2003 | 02:41 PM
Dano 00TA's Avatar
Engine: LS1/L98
A good way to check it is to run the car with it plugged in and tap it with the handle of a screwdriver. If the idle changes at all or it wants to die, it's defective.
specialized
Jun 18, 2022 09:26 AM
86IROC112
Sep 7, 2015 01:37 PM
Logan Bryant
Aug 27, 2015 11:52 AM
NBrehm
Aug 25, 2015 11:49 PM
perZ
Aug 15, 2015 01:17 PM
