Best heads for 305?
Old Jul 18, 2003 | 11:50 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Best heads for 305?
I am looking at getting the S/R Torquer 305 heads but are there any that are better for a good price? The Torquer 305 heads come completely assembled for $540/set. I have looked at AFR and Trickflow but I couldn't find any for a 305 (58cc).
Old Jul 19, 2003 | 06:22 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I have them and I also, port and polished them. They were a great!!! upgrade. In fact my car was slow as **** with my mods it will now beat my dads 85 vette easily. I have other mods also, see sig, however, I have a siameased base and the engine will pull till 5500 with out a problem. I need to get it on a dyno to see how it preforms, not just seat of the pants meter.
Old Jul 19, 2003 | 06:52 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Did you port and polish them yourself or have someone else do it? How much did it cost?
Old Jul 19, 2003 | 08:01 PM
86 IROC's Avatar
AFR 180's can be ordered for a 305, they put 1.94/1.55 valves in them to clear the bore vs. the std. 2.02/1.60's. Also, they can be milled down to around 50-52cc IIRC. They won't be cheap though, but they will work well.
Old Jul 19, 2003 | 08:32 PM
daxfas26's Avatar
Car: cobalt ss/sc, 91 z28, 92 z28
Engine: 385 stroker
Axle/Gears: stock 10 bolt 3.73
why not just get a 350 motor. make the most use out of your probuilt 700r4.
Old Jul 19, 2003 | 09:28 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Because they're too slow.
Old Jul 19, 2003 | 09:30 PM
daxfas26's Avatar
Engine: 385 stroker
haha yeah yeah!
Old Jul 20, 2003 | 08:23 AM
bigals87z28's Avatar
Car: Check The Sig
HAHA 305 rock the house !!
anyway, SR's are the only 305 after market head, unless you count the heads you can buy off th ZZ4 that are really just the vette heads... SR's have the most meat to port the hell out of, just dont go crazy. There is a good artical in... i think it was PHR on what to look for and what not to do when porting. AFR's are $$$$ and no way im spending 1200 on a set of heads, even for a 350 unless its gunna give me some mucho power. J, where did you see 540/a set? were they thoes ones on ebay? i wish i had the money for thoes, i could finaly do my engine stuff.... oh well.
Old Jul 20, 2003 | 01:25 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Yep did it my self, cost $65 for die grinder and kit
Old Jul 20, 2003 | 06:21 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Bigals, that is the price from Summit. That is the cheapest that I have seen an assembled set other than the ones on ebay and shipping was going to be too much. Summit has free shipping and a 10% discount until the end of the month. Now if I could just decide between the 212/218 or the 218/224 cam.
Old Aug 4, 2003 | 08:18 PM
Yarnboy's Avatar
I didn't think you could still get AFR heads for a 305..I wouldn't go with a stock replacement head..even if there is alot to port..
Old Aug 4, 2003 | 09:10 PM
Car: Check The Sig
actualy the SR's are nothing like stock... the intake valve is bigger and the valves are better, spring can take more lift, intake runners flow more, and a 30-40hp gain over stock doesnt make them stock replacements... and a 305 doesnt need that much port to make them flow that much better. the only things i see that the stock heads and the SR heads that match up are the exhaust valve size, chamber, and that it bolts to a 305...
Old Aug 5, 2003 | 11:25 AM
dale davidson's Avatar
ummm
would they get past the sniffer?
Old Aug 5, 2003 | 12:18 PM
Car: Check The Sig
The SR's? yea... they have EGR passages and everything... they are 50 state
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
