No knock sencor!
Old Jul 20, 2003 | 10:37 AM
T/A_SXracer's Avatar
Car: '85 T/A
Engine: 385 full roller
No knock sencor!
i have an older block, if it wasnt originally equiped witha knock sencor, how do i go about my tpi swap. how do i install the knock sencor.? how bad does it affect performance not having one. thanx.
Old Jul 20, 2003 | 10:54 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
You must have a knock sensor. This can be installed in the drain plug on the passenger side of the block.
Old Jul 20, 2003 | 11:00 AM
88blackbird's Avatar
Car: 88 Trans Am GTA
Use the coolant hole like stated above, If it is not the same tread size you will have to use like a brass adapter. I am going to have do the same thing with the 406.
Old Jul 20, 2003 | 03:31 PM
novakm's Avatar
I put TPI on an older block.
I thought the sensors were carefully calibrated at the factory for specific block castings, and don't work well when used on blocks they were not designed for, so I did not use one.
Had to modify the EPROM to disable it in the ECU.
MIke
Old Jul 21, 2003 | 08:40 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
just get one for a 350. just don't use a 305 knock sensor they much more sensative. you should be ok.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
