Should I get a custom grind? (Cam)
Old Jul 21, 2003 | 12:53 PM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
The engine is being put together this week so now I just need to know if I should stick with the cam I chose (LT4 hot cam) or go with a custom grind, or a more suitable off the shelf grind.
Here's the setup
Lingenfelter Super ram (58mm TB, ported/gasket matched base, 30lb injectors)
AFR 195 Heads 2.02/1.6, VERY worked over
355 - All forged internals (zza4 crank, pink rods, TRW pistons)
Custom PROM
2600 Stall converter
1.6 RR's
1 5/8 hedman headers and full exhaust
Here is my goal...
* 16mpg city / 20mpg highway (minimum)
* 345 RWHP
* prefer a slightly warmed over stock sound
* Secondary, looking for a 100k mile engine
If I can get the first two with the LT4 hot cam, I'll be happy. This will be a daily driver.
Any suggestions appreciated.
PS I have already put a cam request into cam motion, but have yet to receive response on what they think the best way to go is.
Old Jul 21, 2003 | 02:20 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The cam manufactures have a pretty good selection of grinds already, unless you're really hardcore and trying to squeeze the last few hp/tq out of your setup, I'd go with what's available and use the extra bucks saved towards something else.
Forget about the "sound"...although a 425+hp 350 will probably have some...if you ask for something with a noticable lope, then you might just be over camming the engine with no positive effects, only negative.
Old Jul 21, 2003 | 02:32 PM
Engine: 355
Thanks for responding mike.
With the sound factor, what I meant to say is I would like to sound as stock as possible. I want this for a couple of reasons:
1. You get that sleeper element
2. The smog ****'s in California here something like that they want CARB numbers, that I will be unable to produce for the LT4 hot cam, but if it sounds normal the idea is that I sohuld be able to get it by.
As far as cam motion here is what they gave me, however this was before I let them know I needed one for daily driven mileage, so they are working on that now.
Duration (intake/exaust) 236/240
Lift (intake/exaust) .571/.574
Lobe Center Separation 110
Intake Centerline 106
Comments LASH .010 HOT
As you can see this is WAY hotter than the LT4 hot cam. Any suggestions on a off the shelf? or any duration / lift numbers I should be looking for?
James
Frozer!!!
Jan 19, 2024 04:55 PM
morrow
Jan 13, 2024 12:29 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
