Electronic speedo works with any tpi ecm?
Old Jul 21, 2003 | 08:21 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
I'm planning to do a TPI swap on my car, and I've already gathered most of the parts I need. I have an 870 ECM and harness from an 85 IROC which I will most likely sell. I plan to go with a 730 ECM and a SD harness, but I was curious as to whether or not I can use the 165 and have a functioning speedometer. I believe all the tpi cars that came with either an 870 or a 165 ECM had a cable driven speedo....correct? Would I still have issues with the 730 ECM?
Old Jul 21, 2003 | 09:06 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
A 730 swap should be fine with what you have now. Just run the VSS wires directly to the ECM instead of the VSS buffer that RS's used.
For a 165 you'd keeop the VSS buffer, not 100% on this off the top of my head but i'm pretty sure the earlier ECMs use a 2000ppm signal instead of 4000. A divide by 2 circuit is easy enough though. You'd want to search to verify details on this though.
Old Jul 23, 2003 | 08:40 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
So basically I just need to remove the vss buffer and run the wiring straight to the ECM if I go with a 730. That sounds easy enough.
I assume the vss buffer is under the dash somewhere, right? What does it look like?
Old Jul 28, 2003 | 12:20 AM
bowtie4ever1986's Avatar
the vssb is behind the cluster and should be about 2.5 inches long and should have three wires coming out of it. i have the same problem but im going to change out the tail shaft.and make it cable.
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
BOOT77
Aug 10, 2015 12:20 PM
marcusaw
Aug 10, 2015 08:13 AM
beachrodder
Aug 7, 2015 04:27 PM
