where to splice o2 sensor 12 volt wire?
Old Jul 22, 2003 | 12:28 PM
chevyismine's Avatar
Car: 91 GTA
Engine: 383 TPI
i have read some of the other posts and learned that when people get the three wire heated oxygen sensor they splice the 12 volt switched ignition to the fuel pump relay. my concern is that i already have a larger fuel pump in it and don't want to overload the relay with the splicing. would it be overloaded or would it be just fine? and if there is a possibility of overload, where else could i splice in (like where exactly, i'm a newbie)? thanks in advance.
chevyismine
Old Jul 22, 2003 | 01:57 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Use a test light to check your fuse panel for a circuit that only has power when the ignition is on & tap into that.
stalkier
Dec 6, 2015 11:25 PM
327IROC85
Sep 23, 2015 12:11 AM
Tweeks25
Sep 17, 2015 08:04 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
