Running Way To Hot!! Help!!
Old Jul 28, 2003 | 04:41 PM
92GNZ28's Avatar
I have a '91 z28 with the 350. Driving w/ the A/C on the car will eventually get up to like 240*+ in this damn Texas Heat. Both fans running all the time, new radiator, new water pump, new hoses, flushed system, new thermostat(180*), good air dam, nothing in between rad. and cond. to block air flow. Runs at good temp w/ A/C off. Don't know what else to do. Know it has good pressure, cuz after shutting car off at 240* it boils over in to the overflow tank. ANY SUGGESTIONS PLEASE!!!
Old Jul 28, 2003 | 10:58 PM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
What percentage of your temp meter is 240*? If it is only a little more than half I wouldn't worry about it.
Old Jul 29, 2003 | 12:28 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
I had a very similar problem. I changed rad cap,thermostat,put in a high flow waterpump, turned fans on earlier with no fix. It turns out my rad was screwed even though I flushed it. Went to a rad shop and had a custom 3 core copper rad made for $300CDN. Works sweet with only one new problem. Runs too cool! Never gets past 1/4 on the temp gauge no matter how hard shes driven in any temp. Im gonna have to change thermostats again. LOL
Old Jul 30, 2003 | 11:42 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
You really should go in and change the prom settings as well as getting one of those fan switches to turn your secondary fan on at a lower temp. That's what I did and I dont see 200* ever.
Old Jul 30, 2003 | 01:17 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
I just figured out what's making mine run too hot, even though I havent fixed it yet. I found my exhaust manifold to be glowing, caused by retarded timing or a bad injector, etc, and it was heating up the engine compartment big time. I unplugged the injector and ran it around, and though it didnt run very well, obviously, it didnt overheat or anything. So get a digital laser thermometer from radio shack or something and check your exhaust manifolds, or run til really hot and open the hood in a dark garage and pull the hood light. Just a thought - I found my problem by chance lol. Good luck!
Old Jul 30, 2003 | 07:00 PM
92GNZ28's Avatar
Well it runs at low temps when A/C is OFF. Only heats up when A/C is on and when accelerating. Doesn't rise when sitting at lights.
Old Jul 30, 2003 | 08:52 PM
jamesbob02's Avatar
Car: 92 Z28
Man I dont know - get a lower temp fan switch and a prom with lower fan turn on/off temps. Not trying to offend, are you sure your thermostat is facing the right way? I HAVE made this mistake before! Is the A/C working properly? Does it happen if you're sitting in park with A/C on? I'd have guys who know stuff just come look at it - maybe they'll know or see something you dont. Where are you in Texas?
theshackle
Mar 5, 2017 06:37 PM
BADNBLK
Nov 16, 2016 09:12 AM
ezobens
Aug 19, 2015 10:29 PM
jackhammer
Aug 15, 2015 10:04 PM
