1988 350 idling problem?!?!
Old Aug 6, 2003 | 08:38 PM
hunterthompson's Avatar
Ok, I really need some help here. Car will idle back and fourth from 500 to 700 rpms. Some times when the car is costing at like 15 to 20 mph it wants to stall, but after a few seconds the rpm's will kick back up. I've changed like every sensor IAC,TPS,MAP..ect nothing no chang . No check engine light , no codes. I Would appreciate any help here It's really getting on my nerves. Tahnkx
Old Aug 6, 2003 | 11:04 PM
bigals87z28's Avatar
Car: Check The Sig
just an idea... check the EGR... sometimes when you run to rich or have a leaky injector, it will cause major carbon build up... take it off and shake it out or clean it with maybe some carb cleaner...
Old Aug 6, 2003 | 11:33 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
EGR or o2, take the vaccum line off the EGR valve and put a bolt in it and then take it for a ride. do this before the o2.
Old Aug 7, 2003 | 09:59 AM
I did all that and still nothing.
Old Aug 7, 2003 | 10:26 AM
Car: Check The Sig
holy chit.. im stumped...well.. not totaly. Are you sure you set the IAC correctly? Did you adjust your TPS? Have you had your engined scanned while running to check for knocks? Could be bad fuel injectors, bad timing, bad knock sensor, chitty gas, or a combo of each...
Old Aug 7, 2003 | 12:17 PM
did all that too. no knock, and I use premium gas.
Old Aug 7, 2003 | 12:27 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Well there is a possiblity that you have a Vac leak, and it may even be on the EGR system even.
jhawkeye
May 25, 2022 06:33 PM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
