88 Plenum on 90 Intake?? Help plz!
Old Aug 7, 2003 | 03:29 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
I need to know if a 88 plenum will work on my 90. I think 88 has the cold start injector....mine dont, so will it work? what will i have to do to make it work? Thanks!
Old Aug 7, 2003 | 04:20 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
I dont think anything is different on the plenum itself except you wont be able to mount the map sensor as there arent any provisions for it. Unless you tap it yourself and make sure its air tight.
Old Aug 7, 2003 | 04:51 PM
Car: 1990 Iroc-Z
where is the map sensor? that what goes on the back pass side of the plenum?
Old Aug 7, 2003 | 04:53 PM
shaggy56's Avatar
Car: 71 Nova
yep
Old Aug 7, 2003 | 04:54 PM
Car: 1990 Iroc-Z
hmmmmm...
thanx alot.
Old Aug 7, 2003 | 10:30 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
My question is, why would you want to put an 88 plenum on a 90 intake? FYI, the IAC and EGR ports between the 88 & 90 are different based on the runners and throttle body you use. You will have to use the throttle body gasket for the 88 plenum.
Old Aug 8, 2003 | 01:43 PM
Car: 1990 Iroc-Z
i have an 88 plenum that has been ported & polished. how hard is it gunna be to put this thing on? i have the bbk 58mm tb. help!!
Old Aug 8, 2003 | 07:14 PM
72LT1VETTE's Avatar
Engine: 350 HO
Axle/Gears: 336
No problem, the bolt pattern is the same. A ported plenum will not give you any improvement without aftermarket runners and ported intake. In other words, the holes in the plenum are bigger but everything else remains the same thus no significant increase in air flow.
Old Aug 8, 2003 | 07:28 PM
Car: 1990 Iroc-Z
yah like ive said before, im a broke ho, so i can only afford 1 piece at a time with this car. runners and manifold are on the way, and headers will shortly follow.
so what mods am i going to have to do to this plenum to make it work on my car? thanx again guys.
Old Aug 8, 2003 | 07:35 PM
Car: 1990 Iroc-Z
here's some pics....
Car: 1990 Iroc-Z
another....
Old Aug 8, 2003 | 07:36 PM
Car: 1990 Iroc-Z
another..
Old Aug 8, 2003 | 07:44 PM
72LT1VETTE's Avatar
Engine: 350 HO
Axle/Gears: 336
No mods needed. Just bolt the sucka on.
Nick McCardle
Sep 10, 2015 08:36 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
