anybody with SVO Inj. and converted LT1
Car: 92 Z28
Engine: Boosted LSX
How did your injectors fit.? I know they are shorter then GM's
Reason I ask is if I put mine in the rails 1st They done seat as far in the intake as they should. and Just the smame if I put em in the Intake 1st They dont go to far in the rails.
Just wondering what everyone else thought/did.
I just dont want a fuel leak when I put the intake back on.
BTW heres a PIC. I still need to polish the top fins and redo the cross over and FPR in mirror black
http://www.cecoatings.com/images/92Z...e/DSC00519.JPG
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I can't recall who sells them, but there are extension pices for the injectors so they seat properly, someone will chime in soon I am sure.
Hey Chris
I have 30# SVO injectors in my LT1 intake. They do not leak at all. I suppose it is possible that once the O-rings get old, they could leak, but I doubt it. I do not currently have the fuel rail retainers around the injectors either. I'd have to cut a groove in the injectors for that. I cut a groove in the LS1 injectors I was using, but ditched those because they wouldn't flow enough fuel.
Car: 92 Z28
Engine: Boosted LSX
Originally posted by S10Wildside
Hey Chris
Hey Chris
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I've run 24# SVO's without a problem either (LT1 intake). I have since swapped to 30# Accel's for more fuel because the 24# injectors were nearly maxing out.
Oops! I'm running 24# SVO injectors. Forgot that I first ordered the 30# Accel injectors, didn't install them b/c I was told that was a bit much for my application, then ordered the 24# injectors.
Anyway, that's irrevelant to your original question. I've got too much going on....I'm forgetting things now.
New2Chevy
Sep 28, 2015 12:35 AM
