pre 89 runners for TPI
Old Aug 9, 2003 | 03:10 PM
smithtc's Avatar
Sometimes things just don't go your way. My thermostat gasket was leaking, so I decided to change gaskets. Figured I'd go ahead and swap some runners I had ported. I knew these were from a pre-89 car, but I didn't notice any difference until I got them partially on. This is after I spent 4 hours removing a stripped bolt.
There is a hole (injector?) on the driver side runner where there isn't one on the 89. Anybody run into this before? Is there a simple way to plug it or block it off? or, Am I destined to use the runners that I just took off?
On top of that I busted my windshield while sitting on it working on the car...
So much for racing this weekend. $200 port and swap job thanks to the windshield alone.
Old Aug 9, 2003 | 03:20 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Sorry to hear your troubles. That hole is for teh cold start injector. They sell a cold start injector delete. Or you can do what i did and go to pep boys or whatever part store and get a similar size freeze plug. Worked out great for me.
Old Aug 9, 2003 | 03:21 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
ahhhhh i did the same thing to my windshield when i was pulling my motor , 300 bucks later...
Old Aug 9, 2003 | 05:01 PM
smithtc's Avatar
I'm going to try tapping and plugging the holes...
EDIT:
No tap for the plug that I have. So I'll try JB Weld or Quick Steel.
Anybody tried that? Forsee any problems?
Quicksteel worked fine...in case anybody runs into same problem.
stalkier
Dec 6, 2015 11:25 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
