View Poll Results: Best cam for my 305 (long)
Voters: 1. You may not vote on this poll
305 guys I need help choosing a cam
Old Aug 10, 2003 | 10:16 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
Its my daily driver so I dont want something too big. I put the choices in the poll at the top. By the time I get around to putting this cam in Im going to change to 3.23s or 3.42s. Im not going to do anything much else to the engine except headers, AFPR, grinding down the egr ears and the walls. Im not going to change the runners or anything because Im going to get an LT1 and 6 spd pretty soon and I dont want to put too much into it, I just want something that will keep up to mustangs and quick daily drivers, like low 14's or something like that. Which cam will work better, one of them claims to go to 5200, is it worth it since Im not changing the intake at all? Id rather go a little slower and keep my stock stuff for now. Also when I do this Im going to be making my own chips so I can tune it as much as I can. Id also rather have a broad tourqe curve rather than a peaky engine since its my daily driver and a five speed. Sorry about the longness but Ive been thinking about this for a while. Thanks for any help :rockon:
Old Aug 10, 2003 | 11:02 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I recommend a CompCam 212/218.
Old Aug 10, 2003 | 11:04 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
http://www.sdpc2000.com/cart.asp?act...1988&pid=29718
Old Aug 11, 2003 | 09:54 AM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Re: 305 guys I need help choosing a cam
Dont waste time with 3.23s or 3.42s, go for the gusto and slap in a set of 3.73s.
Something as small as a F-body LT1 cam will give you low to mid 14's. But you have a M5 and all ready have the abilities to run well into the 14's with all the other mods stated above.
Dont us ethier of those cams use this one Nice cam for a 305 . It will give you all the power you need for low 14's or even into the 13's. Just for comparision here is the cam I just ordered for my less than a daily driver 305, even though it could be. Bigger 305 cam
As for burn your own chips if you make a cam change you should make a tune change. Can you run good with out tune, Yes look at my car. Can I run better if I had a tune to my LT1 cam, yes.
Old Aug 11, 2003 | 10:31 AM
bigals87z28's Avatar
Car: Check The Sig
ZZ4 with ported or aftermarket heads... 3.73's with TPI suck. 3.42's for a mild 305 are fine. You are gunna have to port whatever heads you get to make some serious power.
Old Aug 11, 2003 | 11:36 AM
Engine: hamsters
I dont want to change anything on my engine tho, it only has about 50k on it, thats why I want to leave it alone, with that one they recommend retainers/springs ect.
The "Nice cam for a 305" says not for computers but that wont matter if I can change the tuning right? also with that cam would the 3.23s work better, I was leaning more towards them anyway and since that cam goes to 4500 they seem like the best choice. I might just go with that cam if I can get it to work with the tpi. The most I want to change on my engine is the valve springs and Im going to get roller rockers for sure.
Old Aug 11, 2003 | 12:03 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
My cam is good for a 305 or 350 TPI. The rpm range is 1200-5200rpm. It is recommended for 305 or 350 TPI with stock or modified intake.
It's a Comp Cams. here's the specs-
480/480 lift
210/220 duration @ .050
108 intake centerline
112 LSA.
Here's some sound clips -
Through the Flowmaster
Open cutout
Old Aug 11, 2003 | 02:02 PM
Engine: hamsters
that sounds pretty nasty , how does that cam pull? i want torque all the time at any rpm, wouldnt a 112lsa or higher with less overlap have more "all the time" torque
Old Aug 11, 2003 | 03:39 PM
The pull is awesome. My max horsepower is around 4600-4700rpm. Max torque is at 3100rpm.
The powerband is very broad, no peaky points or anything. I would recommend stiffer valve springs though.
Old Aug 11, 2003 | 05:39 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
As mentioned above, don't forget about the valve springs. They are inexpensive but essential.
Tunedport 335.
When are you going to get that thing dynod in 3rd gear? I've been dying to hear the numbers for that 335 since you built it.
Old Aug 11, 2003 | 05:56 PM
If I had money for Z rated tires I would go dyno again, but I don't
I don't know if you read my previous posts but my first attempt in 3rd gear, at around 125-130mph my rear tires were wrinkling because they're not speed rated high enough So I had to shut down.
But I figure in 3rd gear with the cutout open, around 250rwhp and 360rwtq? Probably springtime I'll have new numbers.
jhawkeye
May 25, 2022 06:33 PM
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Street Lethal
Aug 14, 2015 08:25 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
