tpi on a 79 engine?
Old Aug 14, 2003 | 04:01 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
tpi on a 79 engine?
i am looking to buy some tpi for my camaro but i dont know if it will work. its off a 87 formula its complete. my car is a 92 rs with a 79 350 and 700r the engine has 58cc heads edel torquer cam . . . i assume the intake wont line up with the heads so the holes will have to be worked over. the reason i am wanting to do this swap is for emission and because i was told 58cc is too much comp for iron heads and carb.
what will i need to do to the tpi?
will tpi work with this setup?
will the ecm plug right into my car?
will it make more power than carb?
thanks
Old Aug 14, 2003 | 04:24 PM
87350IROC's Avatar
Car: 87' IROC
1. you will need the plenum, runners, manifold, a matching year ecm, fuel rail, injectors, a MAF, intake ducting, a new wire harness, and all associated sensors, i'm prolly missing some stuff too
2. TPI should work on any gen 1 small block with standard gen 1 heads (ie. not vortec)
3. you may have to make some sort of a bracket to hold the ecm but its no biggie if you can't
4. it depends what kind of power you were running with the carb. What kind of carb, manifold, and heads? a generalization is that it will make more toque and less hp. You will get better gas milage
Old Aug 14, 2003 | 04:53 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
By block is an 80 and I had no problem adapting the TPI to it with the proper heads. Like you said the angle of the center bolts on the intake are at a different angle.
As for power, if you use all stock TPI components and do not port them or do anything to improve the air flow, you may see a decrease in power over the carb. I think it all depends on the combo. You said you have a Torquer cam? I don't think that cam will have good results with a stock TPI. From the specs on the Edelbrock page, I don't think it is a good choice. I suggest something that is designed for use with EFI and TPI...
Good luck...
Old Aug 14, 2003 | 05:01 PM
87350IROC's Avatar
Car: 87' IROC
Like perhaps a ZZ4 cam, its a nice cam and better yet its cheap, around $130 new.
Old Aug 14, 2003 | 06:19 PM
nitrovette's Avatar
Car: 73 corvette
Engine: 2004 ls1
im using my 73 block with sportsman 2 heads from my vette with a 87 t/a setup ,just drilled holes out and fit fine.also with the zz4 cam.
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
