hood clearence problem with the HSR?
Old Aug 20, 2003 | 08:17 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
I am planning on the HSR among other things. I've looked through most of the threads pertaining to the HSR. I was a little suprised of a pic I came across showing just the manifold installed. It looks like it is way to tall as it is, let alone adding the plenum. So the question is this, Is everyone running a cowl with the HSR? I am not opposed to that idea. My Z is in the process of being painted, so getting the hood is only the matter of money. I dont plan on getting the car running and painted until next summer.........
Old Aug 20, 2003 | 09:47 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
The HSR hit my stock IROC hood on the inner bracing (it was actually the throttle body that was hitting). I'm now using a Glasstek 2.5" cowl hood. You could cut out a portion of the inner bracing on the stock hood and it should be okay. I think it would depend on what kind of motor mounts you're using too. I'm using Prothane poly motor mounts and the motor seems to sit slightly higher, adding to the problem.
Old Aug 21, 2003 | 10:18 PM
MYBLUZ's Avatar
Engine: Blown 383
I'm still running the stock mounts, so maybe I'll have more room...But I'll probaly get a cowl. Thanks
Old Aug 21, 2003 | 11:25 PM
Dr G's Avatar
JMatlock88 and others have discussed this issue at some length previously as you have probably found. You may have read these already, but some useful threads include:-
https://www.thirdgen.org/techbb2/sho...hood+clearance
Stealth Ram install - includes pics of hood modifications.
StealthRam- Can it be whacked to fit?
HSR Hood clearance - Solving by lowering motor mounts?
Good luck with your project!
Old Aug 22, 2003 | 04:47 PM
grumpyvette's Avatar
AND HERES a OPTIONAL STEALTH RAM PLENUM OVER 1.2 inches LOWER IN HEIGHT
http://fasterdeals.com/vette/index.html
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Bert87
Aug 23, 2015 03:50 PM
355tpipickup
Aug 22, 2015 06:06 PM
