No Idle
Old Aug 22, 2003 | 11:43 AM
rattlesnake_dm's Avatar
Car: 1992 RS (25 th Anniversary)
Engine: 350 Miniram XFI
Transmission: Pro-Built 4L60
No Idle
Hey guys I need some input. I did a TBI/TPI swap. Took out the 305 TBI and in it's place put the setup listed below. Now I ordered a custom prom to run this and I can't get the car to run. So I took out the custom chip put in the old 305 chip and have had it running for 2 mins. It seems to want to run better with the old chip even with the camshaft. Give some suggestions on problem areas, I know the cam is horrible for TPI, so should I change the cam and see if it runs, get some larger injectors, get a 350 prom...... or what. Tell me what you think.
1992 Camaro RS
25th Anniversary Heritage Edition
Red with Black
Stock TH700R4 Transmission
Stock Stall Converter
Stock Suspension
15" wheels, 225 tires front, 245 tires rear
1968 327 2 bolt main block
10:1 compression
bored .030 over (that puts it at 331 c.i.d)
ground .010 on the mains
TRW hypereutectic pistons
hi- perf seals, moly rings, bearings, rods, rod bolts,
frost plugs, ect.
ARP bolts through out
double roller timing set with thrust button
hi-perf oil pump and drive
baffled oil pan
291 casting heads
64 cc chambers
1.94/1.6 valves (3 angle grind)
1.52 roller rockers
pushrods, guideplates, screw in studs, guides, ect.
polished and ported
camshaft 220/231@.050, 468/480 lift, 110 lsa
1991 Speed Density TPI
Ported, Polished, Siamesed Plenum and Intake
Stock Runners
48mm Throttle Body
19# Injectors
Adjustable Fuel Pressure Reg
350 Knock Sensor
170* stat
Heddman 1 5/8" Longtube Headers with 3" collector
No cat
3" exhaust
the EGR deleted,
the temp at which the fan comes on lowered,
the VATS disabled (going from TBI to TPI, might be a problem ),
the RPM for the VSS extended as I want to rev
Old Aug 22, 2003 | 12:43 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
You might be better off posting this in the DIY tuning forums, but the VE tables is where I would start. Larger lift and longer duration make low RPM VE (Volumetric Efficiency) go down. Lower these numbers a bit, then test it while watching your BLMs. Guessing by the lift/duration given, I wouldn't be surprised if you need a 20% or more change in some areas across the RPM range. Without a dyno with wideband O2 readout, scanner software, or your own wide band O2, you're just going to be stabbing in the dark. Good luck.
Old Aug 22, 2003 | 05:50 PM
I did her. I got her to idle at 750 in park and I was using the stock 305 chip and 19lb. injectors. She is one mean engine!!!!
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
