Can I use stock injectors with this?
Old Aug 25, 2003 | 11:46 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
i have an 85 ta lb9
i'm guessing stock injectors are 19lbs?
can i use them with the following
shorty headers
aluminum l98 heads
lt1 intake
bigger cam? (haven't decided on which cam to go with yet. if you have a suggestion, chime in. emissions is no concern. car will only see limited street use. MPG isn't a real issue either)
Old Aug 26, 2003 | 01:12 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Do a search on webcrawer.com or Yahoo for "Injector Calculator" and you should be able to find an online version of the software needed. You plug in a few guestimate values (projected HP ratings) and you can find the injectors you need, or supply the fuel pressure and injector size, mutiplied by the number of cylinders and you'll get the max projected HP potential with that combination.
From what you've posted, your 19's should be fine for the HP you'll get with those mods. At the most you can do a fuel pressure bump and meet the needs if you get wild...
Old Aug 26, 2003 | 04:07 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Exactly, you'll be fine. As for the cam, I'd go bigger. I'd stay away from a cam w/ more than 550 lift. I don't think the heads will flow in stock form. However, with some porting, I'm sure those heads will make very respectable power.
Old Aug 26, 2003 | 08:00 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
use those injectors and invest in an Adjustable Fuel Pressure Regulator and you'll be fine.
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
z28_AJ
Aug 27, 2015 08:59 PM
ezobens
Aug 19, 2015 10:29 PM
