Replacing Fuel Injectors.
Old Aug 28, 2003 | 07:56 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
I just got done lifting my fuel rail up and pressurized the system, looking for leaks. I am pretty confident #7 and #1 are leaking. Pressure been bleeding down steadily to 10psi in 10-15 minutes or so. I been troubleshooting a hard start when engine is warm, so I think now I have a flood conditon after car sits for an hour or so.
I just wonder if I should just replace the 2 stock injectors, or replace them all? I did have them sent out to Cruzin about 3 years ago, he did find one dripper. Maybe I should them all back to him for another cleaning, or just replace them and be done with it? I would think if 2 are leaking now, then sooner or later the rest will go bad.
I don't really have a need for aftermarket perf injectors, but if the Bosch ones are causing me problems....
Old Aug 28, 2003 | 08:41 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
you can get a set of aftermarket ones the same pounds. or go the next size up and turn the fuel pressure down some to compensate.
Old Aug 29, 2003 | 04:18 PM
Car: 1988 IROC-Z
Well I priced out a new Bosch injector from my local GM dealer. And it was only $163.56!!! That WAS for 1 injector. I think I will just pull them all and send them back to Cruzin for more service. That would be about half the cost of 1 new one!!
Old Aug 29, 2003 | 05:10 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Mike,
Accel and Ford Motorsports injectors are like $240 and $220 respectively for a new set of eight injectors at Summit. They won't be flow matched but I hear that the FMS's are pretty darn close out of the box.
HTH
-Schultzy
Old Aug 30, 2003 | 06:52 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Actually Accel's do come "flowmatched" now.
The set I just bought for my engine build are individually rated at:
58ml 59, 57, 59, 59, 59, 59, 58ml.
Old Aug 30, 2003 | 11:18 AM
Car: 1989 GTA
That is good news. Did you just order the standard set from Summit or something?
-Schultzy
Old Aug 31, 2003 | 07:36 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Yes.
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Firechicken86
Aug 12, 2015 10:07 PM
