OK so i got the lpe219 cam.....
Old Sep 4, 2003 | 01:51 AM
1990irocz28's Avatar
Car: 1990 iroc 5.7
Got the lpe219 cam, what else do i need to install this cam?
the cam that i have right now is a comp cams 206/212 480/487. they put that one in (and lifters springs lock retainers etc.)when i had the engine rebuilt. I know i need to change the prom chip, am i missing anything else?
Old Sep 4, 2003 | 07:45 AM
bigals87z28's Avatar
Car: Check The Sig
id change the rest of the valvetrain if the springs cant hold that much lift. Find the specs on the springs max lift it can take. You might have to get stiffer springs. How about a set of roller rockers? Pushrods is a good idea if the ones you have are stock still. with the higher lift, your pushrods will not be able to take the beating of the stiffer springs and valvetrain.
Old Sep 4, 2003 | 11:14 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I also purchased the 219 cam. Only thing I am upgrading is the springs to a 1.46 Double. Since I already have a cam with .540. I am set with Hardened TF pushrods and Comp Pro Mag rockers. The 219 will max out at .560 lift now.
Old Sep 5, 2003 | 04:19 AM
Car: 1990 iroc 5.7
ok i got new pushrods.....so all i need is springs and rockers? the lingenfelter site does say i need stiffer springs. anymore recomdations on what brand spring and rocker? Thanks alot guys for helping me out.
Old Sep 5, 2003 | 06:37 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Comp Pro Mag 1.6 Rockers. They beet the heck out of the crane golds i think.
jbpnumber03
21
Jun 26, 2008 11:39 AM
PLANT PROTECTION
Jan 26, 2008 07:18 AM
danzig27
Jun 28, 2003 01:24 PM
mult68
Sep 18, 2001 04:46 PM
