first engine swap
Old Sep 5, 2003 | 08:45 PM
mike88form350's Avatar
Car: 88' Formula 350
Engine: 358 ci TPI
Transmission: Tremec T-56
first engine swap
i'm swapping out the stock L98 in my 88' for the Scoogin Dickey vortec TPI crate engine. i have a few questions that i hope you guys can help me with.
1. the L98 has over 110k miles on it, i might decide to replace the water pump, anyone know of a good pump that will work in a serpentine set up?
2. anyone know of a good affordable set of emissions leagal headers w/ y-pipe?
3. i plan on taking the stock fuel system over to the new engine, should i get an adjustable fuel pressure regulator?
4. also how much would it cost to have the 2-bolt main block splayed for a 4-bolt set up?
any other advice would be very helpful.
thanx guys,
mike88form350
Old Sep 5, 2003 | 09:41 PM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
1. get one from a parts store like autozone, murrays etc...
2. hooker 2055's
3. it only affects performance at WOT
4. dunno
y not just tear down your l98, and rebuild that?
Old Sep 5, 2003 | 11:25 PM
Morley's Avatar
Re: first engine swap
Why, if you are rplacing the engine? But and good partsstore will have them, just get a NEW one, not rebuilt.
SLP
Most definately, and get a pressure guage to go along with that.
around $200 for the caps and figure $300-$500 for the machine work to install them.
[/B][/QUOTE]
Old Sep 6, 2003 | 09:42 AM
Engine: 358 ci TPI
thanx for your input guys. the next question is do i need a new PROM? and how much do they cost and who would i get one from.
cam is GM's LT4 hot cam .525"/.525" lift, 218/228 duration @ .050".
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
