Timing wire for 1989 camaro?
Old Sep 19, 2003 | 12:14 AM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
I was looking for a wire to disconnect so I could check my timing tonight but I couldn't find it on the passenger side firewall. Can someone please tell me where to look?
thanks
Old Sep 19, 2003 | 12:30 AM
bigals87z28's Avatar
Car: Check The Sig
if your looking at the engine from the front... it should be on the passanger side, right over the blower motor. Its a Tan wire with a brown stripe. There is a plastic connection right there.
Old Sep 19, 2003 | 03:18 PM
Morley's Avatar
If you don't see it there, look between the reciever/drier and the strut tower, I found it there on my 91 Formula.
Old Sep 20, 2003 | 12:40 AM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
I looked and looked up by the firewall and around the coil but I found nothing
I will keep looking for it. Thanks Morley.
Old Sep 20, 2003 | 07:55 PM
JCee's Avatar
Most likely it should break out of the big wire loom covering running on top of heater box. Not by coil
If decal is still legible on hood it may also reference it and I think give you timing.
Old Sep 20, 2003 | 08:20 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
On my '89 IROC, it's between the strut tower and the fender on the passenger side.
Old Sep 21, 2003 | 02:26 AM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
I found mine in the same place today. Thanks Morley!
camaro11j
Sep 19, 2018 08:49 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Rustyweb7
Aug 9, 2015 03:05 AM
antares57
Aug 6, 2015 07:47 AM
