For the heck of it....
Old Sep 21, 2003 | 03:01 PM
vwdave's Avatar
Here is a dumb question.....
WIth the mods I currently have (see sig) and a stock TPI with AFPR, ram air, 24lb injectors, 265/50/15 BFG Radial GT tires on 8.5" centerline convo pros, 3.42 posi, polyurethane torque arm bushing, how should my car hook?
I personally would think relatively well.
(With the TBI, if I slam it off the line, it wont burn.)
Old Sep 21, 2003 | 07:01 PM
87350IROC's Avatar
Car: 87' IROC
Let me put it this way. I hook perfectly in 70+ degree weather with my setup. In my opinion its almost all in the tires. I don't know how your tires are. Heres my setup.
87' 355 TPI, ZZ4 cam, mild head work, ported TPI
stock suspension
Michelin XGT V 245/50/VR 16 tires
3.27 gears
I have trouble hooking below 70 degrees but traction is perfect in warm weather. Should make for a nice 60' time. Your setup sounds very nice.
Old Sep 21, 2003 | 08:29 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Kinda confused, not that it really matters, but yu have TPI, yet refer to TBI?
Anyway, if you nail the throttle and don't spin..two things could be happening:
1. You're hooking very well.
2. You have an engine or tranny problem, that is causing the take off to be a dog.
Have you run at the track yet? Your '60ft time will be a tell-tell sign of what's going on.
Old Sep 21, 2003 | 08:42 PM
vwdave's Avatar
No track close by. Moroso is over 2 hours away, and it doesn't hook.
I have TBI currently, but I am swapping to TPI soon as it gets polished and all the parts arrive.
Old Sep 21, 2003 | 09:04 PM
87350IROC's Avatar
Car: 87' IROC
Not sure if this is directed at me, i assume it its. No, i havn't had it to the track yet. However i'm definatly #1. Its very strong from a stop. I'm hooking very well. My tires are very soft. IIRC the treadwear rating is 180.
Old Sep 22, 2003 | 09:45 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Sorry, was asking vwdave...I see now he's asking how he'll hook after swapping to TPI.
Loudnproud86
Jul 14, 2016 12:59 AM
kitt23
Exterior Parts for Sale
Nov 28, 2015 06:26 PM
DonW
Carburetors
Sep 23, 2015 08:04 PM
aharvel50
Sep 21, 2015 07:31 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
