Can I run these injecters.
Old Sep 21, 2003 | 09:32 PM
transambill's Avatar
Car: 91 Firebird Formula
Engine: ZZ4 fast burn with TPIS mini ram.
Transmission: Viper T10 6 spd.
I've been given a set of injectors my buddy had in his LT4 GS Vette.They are 28lb. Can I run these in my 88 TPI 350? Or do I need to change anything first? My motor is totally stock
Old Sep 21, 2003 | 09:53 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
You will need to change the injector constant in the .bin file stored in the PROM to run that much larger of an injector. If the size was closer to stock (22lb), you might be able to compensate for it with rail pressure adjustments.
Also, you won't need that big of injector with a stock or even mildly built engine. And are you sure they aren't 24lb?
Why are you replacing injectors?
Old Sep 21, 2003 | 10:51 PM
I was thinking of replaceing them cause they have 130,000 miles on them and was given a set that had less than 25,000.There actually 27.6lbs and were the factor ones in my buddy's LT4.
I'm stupid when it comes to EFI,I'm a carb guy and trying to learn all I can on TPI.
Old Sep 25, 2003 | 04:42 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Your sig. say "89 IROC Majorly Modded"
What kinds of mods?
What injectors are on there now?
What prom or "burn specs" are you using?
Old Sep 25, 2003 | 04:48 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
You would need an ajustable fuel pressure regulator to turn down the pressure a bit and then modify you PROM's injector constant, VE, and PE tables to run those injectors in a stock TPI 350.
I'm making well over 400 hp with 24 lb. SVO injectors and the duty cycle of them at wide-open throttle is no where near being maxed out.
28 lb. 'ers would be good on a stock TPI 350 if you threw some Nitrous on it though!
Old Sep 25, 2003 | 04:51 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
What kinds of mods?
he must have two cars cause he said he wants to put the injectors into an 88, the sig is of an 89
Old Sep 25, 2003 | 08:15 PM
Sorry I need to update my sig.I sold my 89 Iroc and have since
bought a 88 GTA. The Iroc was carbed,355, forged everything Edelbrock heads,intake,bla,bla,bla.88 GTA,stock with the exception of Flowmaster catback and 373's in the rear.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
