Maf
Old Sep 22, 2003 | 08:49 PM
Mitch_Cox_kc's Avatar
Maf
I have a 62 Nova with a 350 TPI unit I put together. Everything is 87 5.7.. I am getting a weird code for the MAF sensor. Its a code 33. When I have my scanner hooked up "tech I" I can read the "Mass Air Flow" rate in g/s the next line is "Airflow" its also in g/s. When the code sets the "Mass Air Flow" will continue to read the value of the sensor but the "Airflow" will be stuck on a number usually around 47 g/s. I have replaced the MAF sensor 3 times and all 3 have acted the same. I am now leaning to a ground or short.. The code will not always set at the same time. Usally it would set at hwy speeds above 2000 rpm.. now it will set under 2000 rpm. I have checked all my grounds on the wire harness Ihooked them to one of the fuel rail bolts under the plemtimn, I have a ground from the left head to the master cyl, and one from the right front of the block to a cross member..
Any ideas???
Mitch
Old Sep 22, 2003 | 09:06 PM
RP1987GTA's Avatar
have you replaced the MAF burn off and MAF power relays?its a good place to start...99% of MAF troubles are solved by replacing the relay(s)
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
