can a LT1 throttle body be used with a TPI injection setup?
Old Sep 25, 2003 | 09:39 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
since i dont hear too much about modding the LT1 intake for the TPI throttle body, i assume they bolt on the same...
i guess my question really is... can the LT1 TPS sensor be made to work with the TPI computer easily? like bolt on, the sensors give the same output or what?
Old Sep 26, 2003 | 08:10 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
well? does anyone know?
Old Sep 26, 2003 | 10:11 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I do know.
The LT1 TB will bolt right onto the TPI intake. You will have to use the TPS and IAC from the LT1 TB. Your TPI wiring harness connectors will need to changed to the LT1 type TPS and IAC sensor connectors. And finally you will have to change your throttle cable to the LT1 style and make a bracket for it.
Sounds like alot of work for nothing, the TB's are the same operationally. No performance increase will be had by changing......
Old Sep 26, 2003 | 10:37 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Travis, What John said.
I had a LT1 BBK TB
Old Sep 26, 2003 | 10:38 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Originally posted by John Millican
I do know.
sweet... thanks.
since im building my own intake ( and using a LT1 one if i cant build it) and converting to TPI from TBI, its just easier for me to get everything from a LT1 car...
thank you.
Old Sep 28, 2003 | 04:49 AM
CHRISMAN2000's Avatar
Car: 1991 Camaro Z28
Engine: 350 L98
Does that mean NOS's 58 throttle body can be used on a TPI.
GOTTA GO AND GET ONE NOW
-ZOOM-
jhawkeye
May 25, 2022 06:33 PM
Terrell351
Jun 13, 2021 01:13 PM
Fast355
Dec 2, 2016 06:33 PM
lakeffect2
Aug 23, 2015 08:44 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
