275hp 305-- new injectors or stock will work-
Old Oct 3, 2003 | 06:48 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
i'm going to be building a 275hp 305
a cam, mild head work, full exhaust, runners,LT1 tb. its going to be a lil bit of a sleeper 305--
(i would go to a 383 setup but i'm not allowed(please do not ask))
i want to knwo what a 305 stock injector is and what can it handle (hp wise)
should i get a set of 350 injectors or what should i do-(no body say makea 350 or bigger)
Old Oct 3, 2003 | 08:04 PM
rockind78's Avatar
Out of curiosity...what is with the LT1 TB?
Old Oct 3, 2003 | 09:59 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
You can run the stock injectors. I am running stock injectors at 315 HP.
Old Oct 3, 2003 | 10:53 PM
Engine: peanut LB9
ok thank you
there is a way to run a LT1 tb on a TPI car my freind is doing it and it came off an LT1, i have a eelbrock LT1 52mm tb sitting in my room just for the hel of it that i won in a bet.
italiano67
Dec 11, 2016 09:21 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
z28_AJ
Aug 27, 2015 08:59 PM
ezobens
Aug 19, 2015 10:29 PM
