EFI for chevy 400
Old Oct 10, 2003 | 12:38 AM
acidpad's Avatar
Car: 1991 RS
Engine: 406 in progress
Transmission: th350
EFI for chevy 400
I'm in the process of designing a build up from a chevy 400 block that i have in my garage, and ive decided that i want to go with some sort of electronic fuel injection. The general concept behind this motor is for it to make ~ 500 HP and possibly have either a turbo (maybe 2) or a supercharger. many of the aftermarket EFI setups that you see through JEGS or SUMMIT have a limit of about 400 to 500 HP. I dont want my injection to be my bottleneck if i decided that i need more power. I'm basically looking for any, and all, suggestion on how to approach this, or setups that are known to handle this kind of power.
Old Oct 10, 2003 | 02:59 AM
bigals87z28's Avatar
Car: Check The Sig
well... best way to make a good 500 would be some type of HSR or mini ram. maybe some type of converted carb set up would be good too. Its all up to how much $$$ you wana dish out.
Old Oct 10, 2003 | 08:30 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
If you don't want the intake setup to be an issue, then look at a single plane intake with a billet TB on top....but it depends on your actual HP goals....
The stealth ram is nice, but not able to be matched to a 1206 Fel Pro gasket....and most large port heads are matched to that gasket...
Not that that stopped me, but I am not using it to its potential, that is for sure....
But the key is to figure out the HP goal first and build your combo from there...
F.I. 57 Belair
Aug 23, 2021 01:09 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
customblackbird
Oct 1, 2015 04:30 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
84 TA NV
Sep 6, 2015 08:02 PM
