oil cooler coolant lines
Old Oct 17, 2003 | 08:22 AM
Adamsy87's Avatar
I'm rebuilding a 350 TPI and I wanted to replace the old oil cooler coolant lines with rubber tubing. Would it be ok to use heater hose? Thanks a lot.
~rick
Old Oct 17, 2003 | 08:58 AM
kevinc's Avatar
Car: 1982 Z28
I'd be worried about them flopping around and hitting the harmonic balancer...stick w/ the steel tubes.
Old Oct 17, 2003 | 09:10 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Are you talking about the "entire" set of cooler lines or are you just referring to the rubber hose part of it?
Old Oct 17, 2003 | 11:27 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Well, you could. But an extra few feet of rubber hose, snaking through / past several moving engine parts would make me pretty nervous. I'd get rid of the oil cooler altogether before i risked such a potential compromise of my cooling system.
Fun Fact of the day: When the corvette went to M1 factory fill in the LT1s. GM stopped using an oil cooler. So even the general would tell you that good oil negates the need for the stock cooler
eightsixseven
Dec 16, 2024 01:50 PM
toronto formula
Nov 10, 2015 06:17 AM
LittleFranks
Sep 17, 2015 12:22 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
