need help with performance
Old Oct 19, 2003 | 08:54 PM
raecar's Avatar
Car: 1987 GTA Trans Am
Engine: 5.7L
i have a 1987 gta trans am with L 98 5.7 L motor. the motor is a new stock motor. i have tpis air foil, afpr, flowtech headers and y pipe, flowmaster exhast, and a hypertech chip. fuel pressure is set at 44 with vac and it reads 54 with out vac. the base timing is 8* btdc. here are my times at the track with the hypertech and the stock chip.
pass 1 2 3 1 2 3
60` 2.155 2.115 2.127 2.129 2.227 2.081
330 6.326 6.25 6.267 6.212 6.321 6.178
1/8 9.791 9.679 9.697 9.62 9.738 9.589
mph 70.37 71.10 71.18 71.90 71.60 71.52
1000` 12.805 12.66 12.686 12.575 12.709 12.553
1/4 15.35 15.179 15.216 15.071 15.216 15.057
mph 88.78 89.59 89.13 90.53 90.13 90.07
that was with the hypertech chip thats with the stock chip
please help me i know it can run faster and i don't want to get beat by all the ford mustangs in my area because they all run in the low 14's to high 13's. btw i live in kansas. thaxs
Old Oct 19, 2003 | 09:18 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Lower your FP. For a stock engine with headers you don't really need more than the stock fuel pressure. If you are still running the original 22# injectors then try 44-48psi with the vacuum line disconnected and plugged. It should read mid 30s with the vacuum line connected.
Old Oct 20, 2003 | 11:30 AM
KYL98's Avatar
Car: 1991 Z28
After you lower the fuel pressure to about 44, try bumpin up the timing to 10* and see what that does on the stock chip......and then practice your 60ft times. Youd be suprised how much you can gain by practicing that. Also, check your trans fluid to make sure its full. I was off in my old 91 with the L98, and a guy checked my tranny fluid, filled it.....and I was right where it should have been. Just my .02....good luck
Old Oct 20, 2003 | 04:07 PM
raecar's Avatar
Engine: 5.7L
thxs guys i will try this and tell u all what it does.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
